Enabling Remote Fax
You can specify settings to use the machine as the server-machine for Remote Fax.
For information on the optional products required to use this function, see "Optional Products Required for Each Function."
If you want to use the machine as a remote fax server machine, set [Dedicated Port Settings] (Preferences) to 'On'. (See "Communication Environment Setup.")
Press [Function Settings] → [Send] → [Fax Settings].
Press [Remote Fax Settings] → [Use Remote Fax].
4.
Press [On] → [OK].
Select [Off] if you do not want to use the Remote Fax function.
» Settings/Registration » Function Settings » Send » Specifying the Fax Settings » Enabling Remote Fax
0CYL-0AX
