Specifying the Minimum Version When Generating a PDF
You can specify the minimum version to assign when generating PDF files.
Press [Function Settings] → [Common] → [Generate File].
Press [Specify Minimum PDF Version] → specify the settings → press [OK].
This mode enables you to set the minimum version range to assign when generating PDF files.
Depending on the functions set for the PDF files, the version assigned may be higher than that specified with this setting.
» Settings/Registration » Function Settings » Common » Generate File » Specifying the Minimum Version When Generating a PDF
0CYL-085
