Trace & Smooth Settings
You can change the recognition rate of line drawings of the original when creating a file with outline graphics.
For information on the optional products required to use this function, see "Optional Products Required for Each Function."
Press [Function Settings] → [Common] → [Generate File].
Press [Trace & Smooth Settings].
4.
Select [On] for <Outline Graphics> → specify the settings for <Graphics Recognition Level>.
Details of each item are shown below.
<Graphics Recognition Level>:
[Normal]:
Sets a standard recognition level. (The data size becomes small.)
[Moderate]:
The recognition level and data size are in between those of [Normal] and [High].
[High]:
Sets the highest recognition level. (The data size becomes large.)
If you increase <Graphics Recognition Level>, the data size also increases. It is recommended that you first use [Normal], and if desirable results are not obtained, try increasing the recognition level to [Moderate] or [High].
You can specify the setting for the image quality level of the background in <Background Image Level>.
<Background Image Level>:
[Data Size Priority]:
The data size is small, but the background image quality is low.
[Normal]:
The data size and background image quality are in between those of [Data Size Priority] and [Quality Priority].
[Quality Priority]:
The data size is large, but the background image quality is high.
Select [Off] if you do not want to perform Outline Graphics.
5.
Press [OK].
This setting is disabled when sending a fax or I-fax.
» Settings/Registration » Function Settings » Common » Generate File » Trace & Smooth Settings
0CYL-083
