High Compression Image Quality Level
If you select PDF (Compact) or XPS (Compact) as the file format in "Scan and Send" or "Scan and Store," you can set the image quality level of the document.
Press [Function Settings] → [Common] → [Generate File].
Press [High Compression Image Quality Level].
4.
Select the image quality level → press [OK].
Details of each item are shown below.
[Data Size Priority]:
The data size is small, but the image quality is low.
[Normal]:
The data size and image quality are in between those of [Data Size Priority] and [Quality Priority].
[Quality Priority]:
The data size is large, but the image quality is high.
This setting is disabled when sending a fax or I-fax.
If you scan an original with many colors when [Text] is selected in [Original Type], the data size and image quality will vary following compression, according to the selected image level. However, if the original is in monochrome or has few colors, it does not matter which image level you select.
» Settings/Registration » Function Settings » Common » Generate File » High Compression Image Quality Level
0CYL-081
