Auto Offline
If the machine is connected to a network that is online, scanning is not possible with [Copy] or [Scan and Store]. If you set [Auto Offline] to 'On', the machine automatically goes offline when the [Auto Reset Time] specified in [Preferences] (Settings/Registration) has elapsed.
Press [Function Settings] → [Common] → [Scan Settings].
Press [Auto Offline].
4.
Press [On] → [OK].
Select [Off] if you do not want to automatically make the machine go offline.
If the Auto Reset mode is not set (the Auto Reset Time is set to '0'), the machine automatically goes offline after approximately two minutes. (See "Auto Reset Time.")
» Settings/Registration » Function Settings » Common » Scan Settings » Auto Offline
0CYL-07Y
