Setting the Gamma Value for Remote Scans
You can set the gamma value to use when scanning color documents into your computer through the Network Scan function. Select the gamma value most suited to your computer settings so that you can print the document from your computer with the optimal density.
Press [Function Settings] → [Common] → [Scan Settings].
Press [Remote Scan Gamma Value].
4.
Select a gamma value → press [OK].
For more information on the Network Scan function, see "Scanner."
» Settings/Registration » Function Settings » Common » Scan Settings » Setting the Gamma Value for Remote Scans
0CYL-07W
