Distinguishing LTRR and STMT Originals
You can designate the way the machine handles LTRR and STMT originals that are placed on the platen glass.
Press [Function Settings] → [Common] → [Scan Settings].
Press [LTRR/STMT Original Selection].
4.
Specify the following setting → press [OK].
Details of each item are shown below:
[Select Manually]:
If you select [Select Manually], a screen enabling you to select the original size appears when scanning.
[Use LTRR Format]:
If you select [Use LTRR Format], the machine always detects the original as LTRR.
[Use STMT Format]:
If you select [Use STMT Format], the machine always detects the original as STMT.
» Settings/Registration » Function Settings » Common » Scan Settings » Distinguishing LTRR and STMT Originals
0CYL-07U
