is the icon for an empty mail box.
is the icon for a mail box with files.
is the icon for a mail box that is set with a PIN.
1
![]() You can specify the following settings:
Register to Quick Menu (See "Quick Menu.")
2
[Name]
Press to sort the files by name, in ascending or descending order.
[Date/Time]
Press to sort the files by date/time, in ascending or descending order.
3
[Edit File]
Press to edit or check a file in a mail box.
4
[Print List]
Press to print a list of files stored in a mail box.
5
[Print]
Press to print the selected file.
6
[Send]
Press to send a file stored in a mail box. |
7
[Display Image]
Press to view the contents of the selected file. |
8
[Details]
Press to check the details of a file stored in a mail box. |
9
[Clear Selection]
Press to cancel the selection of a file. |
10
[Up]
Press to return to the upper level. |
1
[Add Files (Scan and Store)]
Press to add a file.
2
[Delete]
Press to delete a file stored in a mail box.
3
[Move/Duplicate]
Press to move or duplicate files to another mail box.
4
[Merge Multiple Files]
Press to combine multiple files to create a new file.
5
[Insert Pages]
Press to insert a file before a certain page in another file, to create a new file.
6
[Delete Pages]
Press to delete certain pages from a file. |
If you want to scan a color image, it is necessary to expand the memory capacity of the machine with the Additional Memory Type A (512MB).
1
Register/Edit Favorite Settings
Changing the Default Settings
2
[Direct]
Press to scan your document in the same size as your original.
3
[Copy Ratio]
Press to reduce or enlarge the scanning size of the original.
4
[Scan Size]
Press to set the size of the original that you are going to scan.
5
[Favorite Settings]
Press to recall scan settings or register frequently used settings in the Favorite Settings.
6
[Back to Default Set.]
Press to cancel all settings. (The machine restores the default settings for Scan and Store.)
7
[Options]
Press to specify useful scan settings, such as scanning different size originals together or dividing originals into multiple batches.
8
[File Name]
Press to assign the file a name.
9
[Density]
Press to adjust the density for scanning. |
10
[Original Type]
Press to select the type of original (text only, photo only, or both text and photo) you are going to scan. |
11
[2-Sided Original]
Press if you are scanning a two-sided original. |
12
[Select Color]
Press to select the color for scanning.
1
2
[Change Print Settings]
Press to change the print settings.
3
[Change No. of Copies]
Press to set the number of prints when multiple files are selected. This key is displayed only when multiple files are selected. |
4
[Delete File After Printing]
Press to have a file automatically deleted after it is printed. |
5
[Start Printing]
Press to start printing.
1
![]() You can specify the following settings: Register/Edit Favorite Settings
2
[Restore Settings]
Press to cancel the settings that you have changed, and restore the original settings of the file. |
3
[Favorite Settings]
Press to recall scan settings or register frequently used settings in the Favorite Settings. |
4
[Merge Files and Print]
Press to merge multiple files and print as one file. This key is displayed only when multiple files are selected. |
5
6
Press to cancel all settings. (The machine restores the default settings for Access Stored Files.) |
7
[Start Printing]
Press to start printing. |
8
[Options]
Press to specify useful print settings, such as printing in such a way that the prints are made into a booklet, and printing page numbers. |
9
[Store Settings]
Press to store the print settings. |
10
[2-Sided Printing]
Press to make two-sided prints. |
11
[Finishing]
Press to select the Collate, Group, or Staple mode.
12
[Select Paper]
Press to select the paper size/type and the paper source. |
13
[Print Sample]
Press to print a sample of the file to check the print result or the contents of the file. |
1
[Address Book]
Selects a destination from the Address Book.
2
[One-Touch]
Press to recall a destination stored in a one-touch button. |
3
[New Destination]
Press to specify a destination not stored in the Address Book.
4
[Send to Myself]
Press to specify your e-mail address as the destination.
5
[Specify Destinations]
Press to select a sending method.
6
7
File Format
Press to select the file format.
8
[Delete File After Sending]
Press to have a file automatically deleted after it is sent.
9
[Options]
Set useful send functions such as sending different sized originals together or sending 2-sided originals.
10
[Start Sending]
Press to start sending.
11
[Cc Bcc]
Press to specify destinations for the Cc and Bcc addresses when sending an e-mail. |
12
[Delete Dest.]
Press to delete a destination displayed in the destination list. |
13
[Details]
Checks or changes the destination information selected from the destination list. |
14
Destination List
Press to display a list of destinations.
For more information on the icons displayed in the Mail Box, see "Types of Mail Box Icons."
For the procedure regarding [Add Files (Scan and Store)] and instructions on operating the Scan screen, see "Adding a File (Scan and Store)" and "Flow of Scan and Store Operations."
