WARNING |
Do not burn or throw used toner cartridges into open flames, as this may cause the toner to ignite, resulting in burns or a fire.
CAUTION |
Keep toner out of the reach of small children.
If toner is ingested, consult a physician immediately.
If toner gets onto your hands or clothing, wash it off immediately with cold water. Washing it off with warm water will set the toner, and make it impossible to remove the toner stains.
Use only toner cartridges intended for use with this machine.
Do not replace toner cartridges until the message prompting you to do so appears.
You can replace a toner cartridge while the machine is printing.
When the message <Replace the toner cartridge.> appears, approximately 2,000 pages can be printed.
Complete instructions on how to replace the toner cartridge can be accessed by pressing [Previous] or [Next] on the touch panel display
If toner runs out during a print job, the remaining prints are made after you replace the toner cartridge.
1. Open the toner replacement cover.
2. Pull out the toner cartridge.
Pull the toner cartridge out halfway, and then remove it completely while supporting it and keeping it straight with your other hand from underneath.
WARNING |
Do not burn or throw used toner cartridges into open flames, as this may cause the toner remaining inside the cartridges to ignite, resulting in burns or a fire.
Never touch the tip of the toner cartridge or subject it to shock by hitting it. Doing so may cause the toner cartridge to leak.
1. Open the package of the toner cartridge, and remove the toner cartridge.
2. Remove the protective cap of the new toner cartridge.
Twist the protective cap of the new toner cartridge in the direction of the arrow (counterclockwise) to remove it.
1. Push the new toner cartridge in the direction indicated by the arrow on the cartridge.
2. Push the new toner cartridge in until it stops.
Support the new toner cartridge with your hand from underneath while pushing it into the machine with your other hand.
Firmly push the toner cartridge in until it stops. Otherwise, the toner cartridge will be pushed back out, and the toner replacement cover will not close.
CAUTION |
When closing the toner replacement cover, be careful not to get your fingers caught, as this may result in personal injury.
