It is recommended that you consult the administrator for the network you are using when performing the settings in steps 1 and 3.
The machine or printing equipment does not come with printer driver software that can be used on a UNIX platform. (Use LPD to set up a printer in UNIX.)
As the fax option does not come with fax driver software for the UNIX platform, it is not possible to send a fax from a UNIX platform.
Pre-determined ports must be opened in order to initiate network communication using TCP/IP. The required ports can be opened by selecting [On] for the appropriate [Network] settings in the machine. It is recommended that the settings for any unused functions be set to 'Off'. When a port is opened, it is possible for a third person to gain unauthorized access.
