Only the System Manager, SSO-H System Administrator (Administrator), Network Administrator (NetworkAdmin), or Device Administrator (DeviceAdmin) can configure the Quick Menu access restriction settings. For information on the types of administrators, see "Administrator Settings."
If authentication is not set, the Personal buttons are not displayed.
(Quick Menu).
If only the System Manager Settings is set and the authentication mode is not used, the log in screen appears when you press [Restrict Quick Menu Use]. Enter the System Manager ID and System PIN. The default setting for both the System Manager ID and System PIN is '7654321'. (See "Specifying the System Manager Settings.")
