e-ManualTopSite mapHelp
Category Top
Overview of This Function
Overview of Login Services
Login Screens
SSO-H (Single Sign-On H)
Login Screens
System Requirements
Before Logging In to SSO-H
Logging In to SMS
Logging Out from SMS
Managing Applications
Uninstalling Applications
Managing Application Licenses
Installing Applications
Login Service Selection
Uninstalling a Login Service
Confirming System Information
Confirming Application Data
Confirming License Files
Changing the Password
Managing Application Logs
Logging In to SSO-H
Menu for Administrators
Registering/Editing User Data for LDAP Server Authentication
Setting the SSO-H
Setting Password Restrictions
Setting the Lockout Function
Menu for General Users
SDL Format
NetSpot Accountant 3.x Format
NetSpot Accountant 4.x Format
Troubleshooting
Other Trouble
Top » MEAP » File Formats for Local Device Authentication User Information Files
0UKW-113
The following three file formats can be used for importing and exporting user information:
It is recommended that you use the SDL Format, except when sharing user information with imageWARE Accounting Manager/imageRUNNER ADVANCE Tracker (NetSpot Accountant).
Only the information for users that have a department ID assigned is exported with the NetSpot Accountant formats. If no users have department IDs assigned, a 0 byte file is exported.
If you use a NetSpot Accountant format, you may not be able to import users that are automatically registered.
