e-ManualTopSite mapHelp
Top » Flow of Settings » Operations Required Prior to Using the Machine
0UKW-009
This section describes the flow of operations and settings required prior to using the machine, for the functions you will use.
Confirm the Following Settings
Some functions of the machine require optional products and operations/settings.
Also, if you want to use functions that require license registration, see "Adding New Functions." See the flowcharts in this category for functions that require operations or settings.
For information on optional products, see "Optional Products/Software."
For information on the system requirements for using the following functions, see "Optional Equipment and System Requirements."
Printing from a Computer for Printing (USB/network)
Function
Optional Product Required
License Registration
Operations Required
Accessing Stored Files
Network
None*2
Memory Media*1
None*2
Print
UFR II Print
None
PCL Print
None
PS Print
None
Barcode Print
Barcode Printing Kit
Required
Direct Print
None*2
Remote UI
None
MEAP Management Function (SMS)
None
Registering/Updating Software (Delivery)
None
Registering/Updating Software (Manual)
None
*1
The default setting for displaying Memory Media is 'Off'. To use memory media, press [Display Settings] in [Preferences] (Settings/Registration) → set <Memory Media> in [Store Location Display Settings] to 'On'.
*2
To print XPS files, the Direct Print Kit (for PDF/XPS) is required. The optional product requires license registration.
