Canceling Print Jobs
You can stop when you want to cancel a print job at the time data is currently being received or executed. It does not affect the print data of a following job or a job the machine has not yet started processing.
For instructions on canceling print job from the Secure Print screen, see "Secure Print."
If you are not logged in as an administrator, you can only cancel your own jobs.
Press [Status Monitor/Cancel].
Press [Copy/Print] → [Job Status].
Select the job → press [Cancel].
You cannot select and cancel multiple jobs.
4.
Press [Yes].
<NG> appears in the print job log screen for canceled print jobs.
5.
Press [OK].
» Print » Setting the Machine (PS/PCL/UFR II Printer) » Canceling Print Jobs
0C1Y-179
