Available Paper Stock
The paper types that can be used with this machine are shown in the following table. Icons indicating the type of paper loaded in each paper drawer can be displayed on the paper selection screen if you store that information in the machine beforehand. (See "Registering the Paper Size and Type for a Paper Source.")
: Available -: Unavailable
Paper Type
Paper Source
Paper Drawer 1, 2, 3, 4
Multi-Purpose Tray
Plain 1
(17 lb bond to 21 lb bond (64 to 80 g/m2))
Plain 2
(22 lb bond to 24 lb bond (81 to 90 g/m2))
Recycled
Color
(17 lb bond to 24 lb bond (64 to 90 g/m2))
Heavy 1
(25 lb bond to 28 lb bond (91 to 105 g/m2))
Heavy 2
(29 lb bond to 34 lb bond (106 to 128 g/m2))
Transparency
(40 lb bond to 67 lb cover (151 to 181 g/m2))*1
Pre-punched
(20 lb bond to 21 lb bond (75 to 80 g/m2))
Bond
(20 lb bond to 24 lb bond (75 to 90 g/m2))
Labels
Envelope
*2
*1 Use only LTR transparencies made especially for this machine.
*2 If the Envelope Cassette-E1 is attached to to the machine, envelopes can be loaded.
Paper Size
Length x Width
Paper Source
Multi-Purpose Tray
LGL
14" x 8 1/2"
LTR
8 1/2" x 11"
STMT
5 1/2" x 8 1/2"
EXEC
10 1/2" x 7 1/4"
Envelope
ISO-C5
6 3/8" x 9" (162 mm x 229 mm)
*1
COM10 No.10
4 1/8" x 9 1/2" (104.7 mm x 241.3 mm)
*1
Monarch
3 7/8" x 7 1/2" (98.4 mm x 190.5 mm)
*1
DL
4 3/8" x 8 5/8" (110 mm x 220 mm)
*1
Nagagata 3
4 3/4" x 9 1/4" (120 mm x 235 mm)
Yougatanaga 3
Custom Size
5 1/2" x 8 1/4" to 8 1/2" to 14" (139.7 mm x 210 mm to 216 mm x 355.6 mm)
*2
5 1/2" x 5 1/2" to 8 1/2" to 8 1/4" (139.7 mm x 139.7 mm to 216 mm x 209.9 mm)
3 7/8" x 5 1/2" to 5 1/2" x 14" (99 mm x 139.7 mm to 139.6 mm x 355.6 mm)
*1 If the Envelope Cassette-E1 is attached to the machine, envelopes can be loaded.
*2 You can use only Custom Size paper registered in [Paper Type Management Settings] under [Preferences].
For instructions on loading paper, see the following sections:
Paper Drawers 2, 3, and 4 are optional products.
Chlorine-free paper can be used with this machine.
Storing Printouts
When handling or storing paper printed by this machine, be careful of the following points.
How to Store Printouts
Store paper on a flat surface.
Avoid storing printouts in folders made of PVC material, as this may cause the toner to melt and stick to the PVC material. Toner may peel when printouts are folded or creased.
Store printouts in the condition where they are not folded or creased as toner may peel.
Put printouts in a binder when storing for a long period of time (two years or longer).
Printouts may discolor when stored for a long period of time.
Avoid storing printouts in a location subject to high temperatures.
Precautions When Sticking Printouts with Adhesive
Be sure to use insoluble adhesive.
Test the adhesive on an unneeded printout before using.
Before stacking printouts that stuck with adhesive, check that the adhesive completely dried.
» Basic Operations » Available Paper Stock
0C1Y-022
