Feeder
Check the location of the paper jam, and follow the procedure described below, while referring to the directions that appear on the touch panel display, to remove the jammed original.
CAUTION
When removing jammed originals, take care not to cut your hands on the edges of the originals.
Remove any originals from the original supply tray.
Remove any originals jammed inside the feeder cover.
1. Open the feeder cover.
2. Lift the lever.
3. Remove any jammed paper.
Remove any originals jammed inside the inner cover of the feeder.
1. Open the inner cover of the feeder.
2. Remove any jammed paper.
3. Close the inner cover of the feeder.
CAUTION
When closing the inner cover of the feeder, be careful not to get your fingers caught, as this may result in personal injury.
4.
Close the feeder cover.
1. Return the lever to its original position.
2. Close the feeder cover.
CAUTION
When closing the feeder cover, be careful not to get your fingers caught, as this may result in personal injury.
5.
Remove any originals jammed in the underside of the feeder.
1. Open the feeder.
2. Remove any jammed originals.
3. Close the feeder.
CAUTION
Be aware that the light emitted from the platen glass may be very bright when closing the feeder.
6.
Follow the instructions on the screen.
The screen indicating the directions on how to clear the paper jam is displayed repeatedly until the paper jam is cleared.
» Problem Solving » Clearing Paper Jams » Locations of Paper Jams » Feeder
0JJC-0FJ
