      0KCF-0J9
      Setting a Remote UI PIN
      You can set a PIN for access to the Remote UI. All users use a common PIN.
      When Department ID Management is enabled (Setting the Department ID Management), this setting is not required.
      1
      Start the Remote UI and log on in System Manager Mode. Starting the Remote UI
      2
      Click [Settings/Registration].
      3
      Click [Security Settings]  [Remote UI Settings].
      4
      Click [Edit...].
      5
      Select the [Use Remote UI Access PIN] check box and set the PIN.
      If you select this check box, you must enter a PIN to access the Remote UI.
      [Set/Change PIN]
      To set a PIN, select the check box and enter a number of up to seven digits both in the [PIN:] and [Confirm:] text boxes.
      6
      Click [OK].
      If PIN is forgotten
      Set a new Remote UI Access PIN in the settings menu on the operation panel. Perform the following operation on the machine: Press   <System Management Settings>  <Remote UI Settings>  <Remote UI Access Security Settings>  <On>  Enter PIN  <Apply>  Enter PIN (Confirm)  <Apply>  .
      If Remote UI settings are initialized
      The Remote UI Access PIN is also initialized. After an initialization, reset the PIN. Initializing Menu
