Checking/Canceling Send Data (E-mail)
You can check the details of the send data. You can also cancel send while it is sending.
If the Processing/Data Indicator on the operation panel is:
Lit or Blinking
It is sending.
Off
No jobs are sending.
You can cancel the job by pressing [
](Stop).
1
Press [
] (Stop).
When only one job is being processed, press [  ] (Stop) twice to cancel the job.
2
When multiple jobs are being processed, select the jobs to be canceled using [
] or [
] and press [OK].
3
Select <Yes> using [
] or [
] when <Cancel?> appears on the screen and press [OK].
You can also cancel the job by pressing [
] (Stop).
The job is canceled.
Check with [
] (Status Monitor/Cancel).
1
Press [
2
Select <TX Job> using [
] or [
] and press [OK].
3
Select <Job History> using [
] or [
] and press [OK].
4
Select the jobs to be checked using [
] or [
] and press [OK].
5
Press [
] (Status Monitor/Cancel) after you have checked the details of the selected job to close the screen.
