See "Attention (Combination of Copy Settings)" before you start copying.
] (Paper Save Copy) to save paper when making a copy. |
N on 1
2-Sided
Select Layout
Format Settings
Original Orientation
Original Format
2 on 1 1->2-Sided
1->2-Sided
Portrait
Book Type
4 on 1 1->2-Sided
1->2-Sided
Portrait
Book Type
2 on 1 1->1-Sided
OFF
4 on 1 1->1-Sided
OFF
Precautions on 2-Sided Copying
Do not touch your document when making 2-sided copying until the process is complete. After copying on the front side is complete, the document is partially output, reserved, and fed into the machine again for copying on the back side.
Be sure to close the sub-output tray before making 2-sided copying.
If the lever is not set correctly, sheets may not be fed properly, or paper jams may occur.
Open the lower rear cover.
Set the blue-colored paper size switch lever (A) correctly.
Close the lower rear cover.
] (Paper Save Copy).
] or [
] and press [OK].
] or [
] and press [OK].
] (Start).|
(1)
Place the next page and press [
] (Start).* Repeat this step until all pages are scanned.
(2)
Select <Start Copying> using [
] or [ ] and press [OK]. |
