See "Attention (Combination of Copy Settings)" before you start copying.
Precautions on 2-Sided Copying
Do not touch your document when making 2-sided copying until the process is complete. After copying on the front side is complete, the document is partially output, reserved, and fed into the machine again for copying on the back side.
Be sure to close the sub-output tray before making 2-sided copying.
Copying on the back side of a printed document (Manual 2-sided copying)
2-sided copying can be performed manually using a printed document. Place a printed document in the multi-purpose tray to copy on the back side*.
To copy on the back side of a printed document, smooth out the curling edges of the sheets and place them one by one in the multi-purpose tray.
If not securely attached, documents may not be fed properly, or jammed.
Open the lower rear cover.
Securely place the blue color paper size switch lever (A).
Close the lower rear cover.
] (2-Sided).
] or [
] and press [OK].
(1)
Select <Format Settings> using [
] or [ ] and press [OK].![]() |
(2)
Select <1->2-Sided> using [
(3)
Select the orientation of the original using [
(4)
Select the finishing format using [
] (Start).|
(1)
Place the next page and press [
] (Start).
(2)
Select <Start Copying> using [
] or [ ] and press [OK]. |
