If the default paper is registered
The setting screen is not displayed when paper is loaded.
] (Select Paper/Settings).
] or [
] and press [OK].
] or [
] and press [OK].
] or [
] and press [OK].
] or [
] and press [OK].
] or [
] and press [OK].
] or [
] and press [OK].
] or [
] and press [OK].
To register a custom paper, see "Setting a Custom Paper Size."
The registered custom paper is listed at the top. Select it with [
<X>) and within the range that can be defined. |
(1)
Select the direction using [
] or [ ] and press [OK].![]() |
(2)
Specify the size using [
] or [ ] and press [OK]. You can also enter values using the numeric keys.
(3)
Select <Apply> using [
] or [
] and press [OK].
] (Select Paper/Settings) to close the <Select Paper> screen.
