Data Is Reduced and Printed
Perform the following procedure.
<Cause> The setting for the scaling factor is not appropriate.
Solution 1
Perform the following procedure in the printer driver.
Display the [Page Setup] sheet.
Clear the [Manual Scaling] check box.
If the [Manual Scaling] check box is cleared, the scale factor will be set according to [Page Size] and [Output Size] automatically.
Solution 2
Select the [Manual Scaling] check box, then specify an appropriate scale factor according to the paper size to be used.
