Residual Images Appear on Non-printed Areas
Perform one of the following solutions according to the cause.
<Cause 1> Appropriate paper is not being used.
Solution
Replace the paper with that which can be used with this printer.
<Cause 2> Depending on the paper type or the operating environment (high humidity or high temperature environment), residual images may appear on non-printed areas.
Solution
Perform the following procedure in the printer driver.
Display the [Paper Source] sheet.
Set [Paper Type] to one of the following settings.
Currently Selected Setting
Setting to be Selected
[Plain Paper L]
[Plain Paper L2]
[Plain Paper]
[Plain Paper L]
[Heavy Paper 1]
[Plain Paper]
[Heavy Paper 2]
[Heavy Paper 1]
[Heavy Paper 3]
[Heavy Paper 2]
[Envelope H]
[Envelope]
[Coated Paper 2]
[Coated Paper 1]
[Coated Paper 3]
[Coated Paper 2]
[Coated Paper 4]
[Coated Paper 3]
If you change the settings, the toner may not fix onto paper well, and the printing may come out faint.
<Cause 3> The drum in the toner cartridge is deteriorated.
Solution
Replace the toner cartridge with a new one.
