Solution
Specify [Paper Type] properly.
Solution
Replace the paper with that which can be used with this printer.
Solution 1
UFR II Printer Driver
Perform the following procedure in the printer driver.
PCL/PS Printer Driver
See Help of the PCL/PS printer driver.
You can specify the same setting from the printer's control panel.
Solution 2
Solution 3
Perform the following procedure.
Solution
Solution
If <Ennn-nnnn> appears in the display, follow the procedure in "The Message Indicator Is On" to solve the problem.
