For Macintosh users
This section describes the procedure for Windows as an example.
For details on the procedure for Macintosh, see "Driver Guide." For details on the procedure for displaying "Driver Guide", see "Viewing the Driver Guide." |
ON
To <Question 2>
OFF
Turn the printer ON.
Cannot be turned ON
The
Ready indicator is on. |
To <Question 3>
The
Ready indicator is blinking. |
The printer is warming up. Please wait a moment.
The
Message indicator is on. |
The
Job indicator is on. |
The printer is operating. Please wait a moment.
If the printer does not perform printing for a while, perform the print data output or soft reset. |
The
Job indicator is blinking. |
The Paper Source indicator is blinking.
It is out of paper. Load paper.
Online indicator.
The
Online indicator is on. |
To <Question 4>
The
Online indicator is off. |
The printer is offline.
Place it online. |
Printable
To <Question 5>
Not printable
If an error message is displayed, solve the problem following the message.
Connected
Try the following points.
If you are using a hub, connect the printer to the computer directly.
If you are using a long USB cable, replace it with the short one.
If you have another USB cable, use it.
![]() If printing does not work, proceed to <Question 6>. |
Unconnected
Connect the cable properly.
[USB] is set to [On].
To <Question 7>
[USB] is set to [Off].
Set it to [On].
Printable
There is no problem with the printer and driver.
Check the printing preferences in the application.
Not printable
To <Question 8>
Selected
To <Question 9>
Not selected
Select the correct port.
The port to be used cannot be found.
Install the printer driver again.
For details on the procedure for installing and uninstalling the printer driver, see "Printer Driver Installation Guide."
For details on the procedure for viewing "Printer Driver Installation Guide", see "Installation."
Enabled
To <Question 10>
Not enabled
Enable bi-directional communication and restart the computer and printer.
