Online).|
The Online indicator goes off, allowing you to specify the settings on the control panel.
Settings).
] and [
], and then press [OK].
] and [
] and [
] or [
], and press [OK].|
After Jobs
It runs color mismatch adjustment after the first print job after the printer is turned ON is completed.
Immediately
Print color mismatch is adjusted immediately after the printer is turned ON. If color mismatch adjustment is run immediately after the printer is turned ON, it will take some time before it is possible to print.
] and [
] or [
], and press [OK].|
Off
If the printer is used in an environment with wide temperature variation, it may run density control.
After Jobs
It runs density control after the first print job after the printer is turned ON is completed.
Immediately
It runs density control immediately after the printer is turned ON. If density control is run immediately after the printer is turned ON, it will take some time before it is possible to print.
The setting for [First Calibration] is changed.
