Specifying the SD Card Data All Erase Function
When an SD card is installed, you can set the SD Card Data All Erase function using a web browser (Remote UI).
Data cannot be erased by only erasing the file from the SD card, because in this method, only administrative information of the file is deleted although it seems the file is erased. You can erase the whole data by using the SD Card Data All Erase function.
About the files to be erased before the function is set
Because the SD Card Data All Erase function becomes effective only after it is set to be used, any file that is specified to be erased before the function is set cannot be erased.
1
Start the Remote UI, and then log in as Administrator.
2
Click [Settings/Registration].
3
Select [Security] from the [Management Settings] menu.
4
Click [Management Settings].
5
Click [Edit].
6
Enter the password currently set for Current System Manager Password.
7
Set the SD Card Data All Erase function.
(1)
Select the [SD Card Delete All Data] check box.
If the check box is cleared, the printer does not use the SD Card Data All Erase function.
(2)
Click [OK].
