Slots for USB memory devices
The USB ports on the front and back of the printer can be used concurrently. If USB memory drives are inserted into both ports, the one on the front has higher priority.
About USB memory support
The file format FAT32 is supported only.
USB memory drives cannot be read by this printer if:
these drives are partitioned
these drives contain encrypted data
Printers that can be imported
You can import the settings only to the same model from which you export the settings.
When saving/reading settings using USB memory devices and SD cards
Connect a USB memory device or an SD card to the printer's USB port or SD card slot. The saving location/writing source priority is shown below.
"USB memory" > "SD card"
Settings).
] and [
], and then press [OK].
] and [
] and [
], [OK] is pressed, the printer's settings are saved to the targeted saving location.
Settings).
] and [
] and [
] and [
], and [OK] is pressed, the printer's settings are read from the targeted writing source.
For details on a hard reset
