In the Remote UI, you can specify the settings by accessing the printer from a Web browser via a network.
Before configuring the protocol settings
When configuring the protocol settings for the printer using the above software, the TCP/IP protocol must be able to be used in your network environment.
Make sure that each setting option for TCP/IP is specified, the printer and computer are connected properly, and the printer is ON.
When specifying the settings using software other than the Remote UI
You can also specify the settings using the following software.
You can specify the settings by accessing the FTP server of the printer using Command Prompt.
When the [Use NetWare] check box is cleared
The printer is not detected on the NetWare network.
Select [Bindery PServer] from [Print Service].
In [File Server Name], enter the file server name created in "Configuring NetWare."
In [Print Server Name], enter the print server name created in "Configuring NetWare."
4.
In [Print Server Password], enter the password for the print server.
5.
In [Printer Number], enter the same printer number as the one specified in "Configuring NetWare."
6.
Specify the settings for [Service Mode], [Printer Form], [Polling Interval], and [Buffer Size] as needed.
Select [NDS PServer] from [Print Service].
In [Tree Name] and [Context Name], enter the name of the tree to which the print server belongs and the context name.
4.
5.
6.
Select [RPrinter] from [Print Service].
4.
Select [NPrinter] from [Print Service].
4.
After performing a hard reset or restarting the printer, the settings are effective.
To perform a hard reset
You can perform a hard reset using the following procedure.
