When using IPPS printing
You need to obtain the public key for this printer and install it on Windows Vista, 7 or Server 2008.
For details on the procedure for obtaining the public key, see "Obtaining the Public Key for This Printer When Using SSL Encrypted Communication." |
About the screenshots
This procedure is described using screenshots from Windows 7.
If printing is restricted
You cannot install the printer driver.
If printing is restricted after the installation
If the IP address of the computer on which the printer driver is installed is restricted to perform printing in [Receive/Print Range Setting], you cannot print from the computer.
(1)
Select [Select a shared printer by name].
(2)
Enter "http://<the IP address or name of the printer>/ipp."
(3)
Click [Next].
About IPPS
IPPS can be used only when the SSL encrypted communication function is enabled.
For details on the SSL encrypted communication function, see "Setting Keys and Certificates."
When you are using the IPP authentication function
If you are asked to enter the password, enter the user name and password, and then click [OK].
(1)
Select [Network printer].
(2)
Click [Next].
(1)
Select [A network printer, or a printer attached to another computer].
(2)
Click [Next].
(1)
(2)
Click [Next].
About IPPS
For details on the SSL encrypted communication function, see "Setting Keys and Certificates." |
