Advantages
You can print relatively faster than when using other applications.
When printing in Windows, the print settings using RAW are easier than using other print applications.
Disadvantage
You cannot obtain the detailed information about print jobs.
RAW is supported as standard by only Windows, not supported by Macintosh, UNIX, and Linux.
Usage Example
If you are using Windows and want to use the printer immediately after installing it
Setting Method
