In order to set a user name and password
You need to set up the SSL encryption communication function in advance.
(1)
Select the [Change Password] check box.
(2)
Enter password.
You can enter up to 24 characters. |
(3)
Enter the same password in the [Confirm] field.
(4)
Click [OK].
If a Message AppearsA message will be displayed if there is anything wrong with the settings. See Steps 6 to 10, and check the settings.
After performing a hard reset or restarting the printer, the settings are effective.
To perform a hard reset
You can perform a hard reset using the following procedure.
