Direct Print from the Remote UI
You can specify PDF, TIFF, JPEG, PS, EPS, or XPS format image files from the remote UI and perform Direct Print. For details on operating the Remote UI, see "Remote UI."
<Direct Print using Command Prompt>
You can Direct Print using the LPR command line.
When printing image files using the direct print function
Note the following when printing image files using the direct print function.
JPEG data is in compliance with the specifications of ITU-T recommendation T.81. TIFF data is in compliance with the specifications of Adobe TIFF Revision 6.0.
The supporting status of encoding methods for JPEG data is as follows.
Supported encoding method
DCT baseline Unsupported encoding methods
DCT extension Reversible compression Hierarchical The supporting status of encoding methods for TIFF data is as follows.
Supported encoding methods
Uncompressed ITU-T recommendation T.4 One-dimensional coding ITU-T recommendation T.4 Two-dimensional coding ITU-T recommendation T.6 Basic facsimile coding ITU-T recommendation T.81 JPEG (Basic DCT only) PackBits (Apple Macintosh PackBits) LZW Unsupported encoding methods
ITU-T recommendation T.82 JBIG ITU-T recommendation T.43 JBIG ITU-T recommendation T.44 MRC |
If you cannot print a file using the direct print function or if the printing position is skewed
The file may be printed properly by opening it from an application and using the printer driver.
