Paper Type
Paper Size
Plain paper
(16.0 to 23.9 lb Bond (60 to 90 g/m²))
Heavy paper
(24.0 lb Bond to 44.4 lb Cover (91 to 120 g/m²))
Standard size:
A4, Legal, Letter Custom size:
5.00 to 8.50 in. (127.0 to 215.9 mm) wide and 11.00 to 14.00 in. (279.4 to 355.6 mm) long |
Before performing 2-sided printing, see "Attention (1-sided Printing and 2-sided Printing)."
Do not touch the paper during 2-sided printing until it is output completely. The paper is first output partially after the front side is printed, and then it is fed again to be printed on the reverse side.
Be sure to close the output selection cover before performing 2-sided printing.
Printing on the reverse side of paper that was previously printed (Performing 2-sided printing manually)
Using the multi-purpose tray, this printer enables you to perform 2-sided printing manually by inserting the reverse side of the paper* that was previously printed.
When printing on the reverse side of paper that was previously printed, flatten the curl and load one sheet of paper at a time in the multi-purpose tray.
The screen may vary according to the operating system, as well as the type and version of the printer driver.
