If you cannot output data
You cannot output data for the following jobs or in the following state.
Data from the PCL/PS/UFR II printer driver
The state where the
Message indicator is onPerform a soft reset.
The data that is being printed is deleted.
When you output data, print it again.
About automatic output
When [Timeout] under [Interface] in the Setup Menu is set to [On], even less than a page worth of data is discharged automatically. (Data from the PCL/UFR II printer driver is not output.) [Timeout] for a job is set to 15 seconds in the default settings.
Reset).
] and [
], and then press [OK].
The data remaining in the memory is printed.
If the
Job indicator does not go off even after outputting the dataPerform a soft reset.
