Do not turn the printer ON immediately after turning it OFF.
If you want to cycle the power of the printer, wait at least 10 seconds before turning it ON again.
If the printer does not operate properly
If an error message appears in the display on the control panel
Precautions when turning OFF the printer
If you turn the printer OFF, all print data remaining in the printer memory will be erased.
Power consumption when the power is OFF
Even if the power of the printer is turned OFF, power is consumed only slightly while the power plug is inserted in the AC power outlet.
To cut the power consumption completely, unplug the power plug from the AC power outlet. |
