Adjusting Paper Conveyance for 2-Sided Printing
This adjustment can be made if the corners of thin or plain paper fold or bend during double-sided printing.
This mode may affect paper feeding. Since increasing the value to a great extent may cause paper jams, adjusting the values in small increments is recommended.
Press
(Settings/Registration).
Press [Preferences] → [Paper Settings] → [Paper Type Management Settings].
Select the paper type that you want to edit from the list → press [Details/ Edit].
4.
Press [Change] for <Adj. Paper Convey. (2-Sided)>.
5.
Press [-] or [+] to adjust the paper conveyance → [OK].
You can also use the numeric keys.
Judge corner-fold surfaces when the paper has been output into the output tray.
Adjust by matching to the paper face on which corner fold occurred.
Corner-fold on printed paper
Adjustment Direction
When the corner folds to the front side
Press [-]
When the corner folds to the reverse side
Press [+]
6.
Press [OK].
