Consumables
The following consumables are available from Canon. For more information, contact your local authorized Canon dealer.
We recommend that you order paper stock and toner from your local authorized Canon dealer before your stock runs out.
Recommended Paper
In addition to plain paper (11" x 17", LGL, and LTR size), recycled paper, color paper, transparencies/clear/translucent film (recommended for this machine), labels, and other types of paper stock are available.
CAUTION
Do not store paper in places exposed to open flames, as this may cause the paper to ignite, resulting in burns or a fire.
Some commercially available paper types are not suited for this machine. Contact your local authorized Canon dealer when you need to purchase paper.
To prevent moisture build-up, tightly wrap any remaining paper in its original package for storage.
For high-quality printouts, use paper recommended by Canon.
Toner
If a message prompting you to replace the toner cartridge appears on the touch panel display, replace the used toner cartridge with a new one.
Toner comes in four colors: black, cyan, magenta, and yellow.
Check the toner color that you need to replace before ordering toner from your local authorized Canon dealer. Also, when replacing the toner cartridge, make sure that you replace toner of the correct color.
Use only toner cartridges intended for use with this machine.
For optimum print quality, using Canon genuine toner is recommended.
Supported Canon Genuine Toner
Canon imagePRESS Toner T02 Black
Canon imagePRESS Toner T02 Cyan
Canon imagePRESS Toner T02 Magenta
Canon imagePRESS Toner T02 Yellow
WARNING
Do not burn or throw used toner cartridges into open flames, as this may cause the toner remaining inside the cartridges to ignite, resulting in burns or a fire.
Do not store toner cartridges in places exposed to open flames, as this may cause the toner to ignite, resulting in burns or a fire.
If you accidentally spill or scatter toner, carefully wipe up the loose toner with a damp, soft cloth and avoid inhaling any toner dust. Do not use a vacuum cleaner that is not equipped with safety measures to prevent dust explosions to clean up loose toner. Doing so may cause damage to the vacuum cleaner or result in a dust explosion due to static discharge.
CAUTION
Keep toner out of the reach of small children. If toner is ingested, consult a physician immediately.
Store toner cartridges in a cool location, away from direct sunlight. (The recommended storage conditions are temperatures below 86°F and humidity below 80%.)
[Be careful of counterfeit toners]
Please be aware that there are counterfeit Canon toners in the marketplace. Use of counterfeit toner may result in poor print quality or machine performance. Canon is not responsible for any malfunction, accident or damage caused by the use of counterfeit toner.
For more information, see canon.com/counterfeit.
Staple Cartridge in the Stapler Unit
Finisher
Staple Cartridge
Name
Shape
Finisher-AN1
Saddle Finisher-AN2
Staple-N1
Staple Cartridge in the Saddle Stitcher Unit
Finisher
Staple Cartridge
Name
Shape
Saddle Finisher-AN2
Staple-P1
Genuine Supplies
Canon has developed and manufactured Toner, Cartridge, and Parts specifically for use in this machine.
For optimal print quality and for optimal machine performance and productivity, we recommend that you use Genuine Canon Toner, Cartridge, and Parts.
Contact your Canon Authorized Dealer or Service Provider for Genuine Canon Supplies.
» Maintenance » Consumables
0S9Y-097
