Auto Eject Paper on Stacker Tray
If [Auto Eject Paper on Stacker Tray at Job End] is set to 'On', the tray automatically moves to the outside of the stacker when the tray is full or the job is complete. This function is useful if you remove the stack of paper in each job.
This mode can be set if the High Capacity Stacker-G1 is attached.
(See "High Capacity Stacker-G1.")
Press
(Settings/Registration).
Press [Function Settings] → [Common] → [Paper Output Settings].
Press [Auto Eject Paper on Stacker Tray at Job End].
4.
Press [On] → [OK].
Select [Off] if you do not want the tray to be moved automatically.
