If a paper jam occurs in paper sources, a screen prompting you to remove the jammed paper appears on the touch panel display. Check the location of the paper jam, and follow the procedure described below, while referring to the display of the screen, to remove the jammed paper.
The Stack Bypass-B1, POD Deck Lite-B1, and Multi-drawer Paper Deck-B1 are optional products.
