This mode is only available for storing files in the memory media.
PDF (Limited Color) is only valid with the following settings:
Select Color: Auto (Color/Gray), Full Color, or Grayscale
Resolution: 300 x 300 dpi
Copy Ratio: 100% or Auto
(Main Menu) → [Scan and Store] → [Memory Media].
If you select [Limited Color] for PDF file format, the color mode is changed from [Auto (Color/B&W)] and [Black & White] to [Auto (Color/Gray)] and [Grayscale]. If you want to scan the document with the color mode that you specify, change the PDF file format to anything other than [Limited Color], [Compact], or [Trace & Smooth].
If you select [Limited Color] for PDF file format, you can reduce the file size. For more information, see "Setting the Resolution for Limited Color PDF."
