[Normal], [Photo]*, [TR Normal], [TR Photo], [Download Profile]
This setting allows you to define the profile that is appropriate for the data you are going to print. It is applied to all data in the print job, so make sure the selected profile is right for your job.
Settings can be applied separately for text, graphics, and image data.
Under most circumstances, it is preferable to select [Normal] for text and graphics data, and [Photo] for image data.
This setting prints the colors closely matching the ones displayed on your monitor.
This setting prints colors close to photographic prints.
This setting prints the colors closely matching the ones displayed on your monitor, and also reduces toner bleeding of text and fine lines.
This setting prints colors close to photographic prints, and also reduces toner bleeding of text and fine lines.
This setting uses a custom profile that you have downloaded from the host computer to this machine using NetSpot Resource Downloader. You can store up to 100 profiles.
You can also download the profile from imageWARE Enterprise Management Console.
If a profile with the name of "None" is downloaded to the machine, the profile is not applied and the [None] setting on the menu is applied.
If [None] is selected for the 'RGB Source Profile' or 'CMYK Simulation Profile', or if [Off] is selected for 'Use Grayscale Profile', an Output Profile setting is not applied to device dependent color data.
