To use the Superimpose Image mode, the image form must be registered in the machine beforehand. (See "Registering Forms for the Superimpose Image Mode.")
(Main Menu) → [Copy].
<Back Side> can only be selected for a two-sided original.
To specify the same settings as <Front Side> for <Back Side>, press [Same as Front Side].
icon. Image forms stored in the CMYK color format are indicated with a
icon. (Color image forms are indicated with a color icon.)
If the color format of the selected image form is CMYK, only [Auto (Color/B&W)] can be selected.
If [Use Auto (Color/Black & White)] is set to 'Off', [Auto (Color/B&W)] is not displayed. (See "Restricting Use of Auto-Color Select.")
Copy modes other than the Shift or Mirror Image mode can only be used for copying images.
You can register up to 100 image forms. However, this number varies depending on the capacity of the hard disk.
Printing performance may not be optimal, depending on the content of the original and image form.
The moiré effect (a shimmering, wavy pattern) may occur, depending on the content of the original and image form.
The check print is a sample print. The actual printout may vary slightly with the check print.
